1992 Chevy Camaro fan problem
1992 CHEVROLET CAMARO
133,000 MILES • V8 • 2WD • AUTOMATIC
CAMAROMAN1992RS
I have a 1992 camaro rs with the 305 tbi, The fan would not kick on so i replaced the temp switch, temp censer, tested the fan motor and it works, and the fan relay. I hooked up a adjustable thermostat and it would turn the fan on, but i want it to be the original way. I am not sure what else to check?
May 25, 2009 at 5:47 PM
If the fan works, the relay is good, and the temp sensor is good, either you have a problem with the computer or there is a broken or corroded wire. Have you checked the wiring for continunity?
Jul 3, 2009 at 7:54 PM
