1992 Chevy Camaro cam shaft seal
1992 CHEVROLET CAMARO
DEANMAN69
Transmission problem
1992 Chevy Camaro 6 cyl Two Wheel Drive Manual
i am changing the clutch in my camaro and as i was doing it i noticed a very small amount of fluid leaking from the cam shaft rear seal i just wanted to know if there was a way i could use hi temp gasket sealer on it or is it an actual seal
Apr 4, 2009 at 11:00 PM
DOCFIXIT
  • 18,828 POSTS
The cam plug is a core similar to a freeze plug is it the rubber seal around crank?
Apr 5, 2009 at 2:56 PM
