Are you sure the radio works? Also, you need to make sure your wiring was correct. And finally, check the in-line fuse that's in the red power wire that feeds the radio.
To check for power, you need a test light. Remove the red power wire and probe that for voltage. If there's voltage, then you need to check the ground circuit. If there's a good ground, then your radio doesn't work.
If there's no power, then probe the circuit backwards to the fuse box until you find a break in the wire or a bad connection. If you don't have a good ground, then find one in another location.
Jan 8, 2010 at 9:10 PM
