1991 Chevy Camaro no fuel no spark
1991 CHEVROLET CAMARO
98,000 MILES • V8 • 2WD • MANUAL
AUTOMAN47GE
i have no spark no fuel through injectos but have fuel pressure and pulse but wont run and after a few attempts to start will all of a dudden start and run but not all the time
Oct 26, 2009 at 3:52 PM
DOCFIXIT
  • 18,828 POSTS
Mostlikely the Electronic Spark Control located on firewall left near brake booster.Believe Auto Zone can test
Oct 26, 2009 at 4:10 PM
JDL
  • 16,098 POSTS
Welcome to the forum. Are you TBI fuel injection? How long since a tune-up, plugs- plug wires- cap- rotor- all filters? Any codes? Did you use a gage and check fuel pressure? Check the coil primary circuit, pink wire goes hot with the key on, the negative wire should have a pulse with engine cranking. Timing ok?
Oct 26, 2009 at 4:13 PM
