Problem started: engine turns will not start1. Checked. had weak fire from coil to distr. no fire from distr to plugs 2,. changed rotor and cap, plugs, ignition coil module in distr and coil then reset timing. Now engine starts idles until it reaches normal operating temperature then dies. what is the problem?
Nov 11, 2008 at 4:58 PM
