1991 Chevy Camaro ecm
1991 CHEVROLET CAMARO
GENEMUSHRUSH
Engine Mechanical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
where is the ecm and prom located on 91 camaro.
and how do i know if ecm may be bad. i was wondering becuase i could crank the car up and unplug the map sensor, the mass air flow sensor and idle air control sensor and i heard no changes in the engine. Before if i did this the engine would shut off immediatley. the engine runs bad anyway and i cant figure it out it idles very roughly. but will take the throttle and sound fine when i put my foot on the accelorator.
Oct 27, 2009 at 3:29 PM
DOCFIXIT
  • 18,828 POSTS
ECM behind right side dash prom inside small flap.
Have you checked for codes?
Oct 27, 2009 at 3:35 PM
