1991 Chevy Camaro A spark plug wire broke while driving
1991 CHEVROLET CAMARO
1TOUGHCHEVYBOY
Engine Mechanical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
Ive changed the plug, the wire, the distributer coil, the distributer, set the timing & it still wont fire up, but it will rotate... Can you help???
May 28, 2010 at 9:02 PM
If you have spark.Next step-check the fuel pressure,you might not be getting fuel.
May 28, 2010 at 9:12 PM
1TOUGHCHEVYBOY
@ rasmataz, thanks I've checked the fuel preasure. I am getting gas to the carb... Thanks again....
May 29, 2010 at 11:52 AM
If you're getting fuel and spark and its not starting check the valve and ignition timing
May 29, 2010 at 12:20 PM
