Engine Mechanical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
i bought a1991 camero 5.7 v8 the person i bought it from said it blew a head gasket so they took it a part and had the heads resurfaced and the valves down and pressure tested put it back together and it had 2 dead cyl so i bought the car thinking the valves were to tight but i was wrong so i took that head off my self and had it tested and it was fine so then i was told the rings were causing the problem so i put in new piston rings and thguy already put in new lifters so then none of this help so i put in new lifters and plugs and cap rotor and check the plug wires still have the same problem but now i have three cylinders missing can you help? thanks bill
Mar 21, 2010 at 10:37 AM
