My 1990 Camaro IROC Z (5.7 TPI) has been running fairly well, but as of lately, I notice that when I get on the highway and go 60-65, between 2000 and 2500 RPMS, the engine has a stutter to it. I noticed it when I looked at my tachometer and it was dropping a few hundred rmps in a non-rythmic matter. It doesn't happen at any other time when I drive it, just in that RPM range. I replaced the fuel injectors a little over a year ago with higher pressure fuel injectors (22#instead of 19#), but it never had a problem until now. I was wondering if it was possible that I had a vacuum leak or if it was the fuel pressure regulator or maybe even my fuel pump. Any information would be greatly appreciated.
Thank you,
jhuerta22
Thank you,
jhuerta22
Jun 6, 2010 at 7:09 PM
