1989 Chevy Camaro GET IT TO START
1989 CHEVROLET CAMARO
48,000 MILES • V8 • 2WD • AUTOMATIC
DBRESLER
  • 4 POSTS
I have a 1989 camaro rs turn switch on get nothing.i checked battery it ok,starter,solenoid ok put in new safety neutral switch,ignition switch and checked all fuses
there ok.
Sep 9, 2010 at 1:44 PM
Hi dbresler, Welcome to 2carpros and TY for the donation
Inspect and test all the fusible links and then report back -power has to go thru the links before it goes anywhere such as the ignition switch/headlights
Sep 9, 2010 at 1:52 PM
DBRESLER
  • 4 POSTS
All fusible link are good
Sep 9, 2010 at 2:54 PM
Double check the ignition switch for power going into it-also check the main wiring harness,also battery and connections.
Sep 9, 2010 at 3:03 PM
DBRESLER
  • 4 POSTS
Idid all that and nothing
Sep 9, 2010 at 3:49 PM
Once again- If there's no power to the ignition switch I strongly suggest you triple check the fusible links if okay inspect the main wiring harness thoroughly-
https://www.2carpros.com/forum/automotive_pictures/12900_s1_66.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_s2_58.jpg
Sep 9, 2010 at 4:41 PM
