1987 Chevy Camaro everything
1987 CHEVROLET CAMARO
GARAGE CHICK
Engine Mechanical problem
1987 Chevy Camaro 6 cyl Two Wheel Drive Automatic unknow miles
the car sat for a while when i got it. is there a certain way to reset the computer if it needs to be. it almost starts is there anything i need to know
Dec 16, 2008 at 11:29 PM
Do below and see what happens then get back we got a long way to go.
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Dec 16, 2008 at 11:49 PM
