1987 Chevy Camaro converting fuel injction harness to carb.
1987 CHEVROLET CAMARO
79BRUIN
Electrical problem
1987 Chevy Camaro 6 cyl Two Wheel Drive Automatic ? miles
I have a car with what i think had a 2.8 liter v6 and 700r4 automatic transmission but no longer has either, how do i use the fuel injection harness to work with a 350 motor with a carb and auto transmission, and what part do i need i dont have money to buy a fuel injection system or motor and dont care about emmision prblems.(by the way I dont have alot of money.)
Mar 17, 2009 at 11:05 AM
CODY123
  • 4 POSTS
You will not use the majority of the wires in the harness, that is of course with the exception of the starter wire. A carburated Chevy 5.7 350c.i. is a very mechanical engine and requires little if any electrical devices, depending on the preference of the owner. Cutting the excess wire is not recommended, unless you are confident in your skills as a technician. Many of the wires can be cut, but a wiring diagram should first be consulted to ensure there are no accidental cuts or mistakes.
Mar 18, 2009 at 1:04 AM
