1987 Chevy Camaro 2.8L hesitation
1987 CHEVROLET CAMARO
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
1ST THIRDGEN
I have changed fuel pump/filter, air filters, distributer cap, rotor, wires, plugs, timing chain/sprockets, checked the IAC valve, cleaned throttle body, checked EGR, checked coil pickup, and fuel pressure. The fuel pressure was checked at idle without disconnecting the vaccum line from the fuel pressure regulator and it read 35 psi. The car runs great at idle until you put it in gear then it will not rev and there is no power. Shut it off and let it sit for a while then it will rev again in park but put it in gear again and try to rev and it will not. car will shift so not torque converter lock-up. PLEASE help I am out of my league, can't figure it out.
Jun 26, 2008 at 7:11 PM
DOCFIXIT
  • 18,828 POSTS
Recheck the fuel pressure it should be higher 45 also take vac line off reg. should go up. Whtch gauge as up put in gear and rev. does it fall off?
Jun 27, 2008 at 8:18 AM
