Engine Mechanical problem
1985 Chevy Camaro V8 Two Wheel Drive Automatic
Hi recently I bought a camaro and it needed bigger injectors in it. so i put the injectors in it and it still is acting like it isnt geting any gas because when i let it idle it stays runing but smokes real bad (white smoke) but when i push the gas it cuts out and dies on me. its a 383 stroker tuned port injection and has a regulator on it iv turned it up and down for hours and still got the same results. the only difference is wen i tune the regulator the idle gets hire or lower. im asuming its a bad regulator but i want professional advice before i go buy one. can you help?
Oct 5, 2008 at 1:12 AM
