engine stalls at idle
1985 CHEVROLET CAMARO
MARK85345
Engine problem
1985 Chevy Camaro V6 Two Wheel Drive Automatic 175000 miles
When my car is sitting out in the cold overnight and I go to start it in the morning it dies when it idles and I have to rev the engine for a couple minutes to start it. Check engine light comes on; seems to occur mostly in cold weather.
Dec 9, 2007 at 6:26 AM
Check the coolant temperature sensor, idle air control valve and throttle position sensor
Dec 9, 2007 at 6:39 AM
I think you should run the codes to see which ones are stored, here is a guide to help.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
A vacuum leak can cause this issue as well, here is a guide to help you fix it.
https://www.2carpros.com/articles/stall-at-idle
Please go over these guides and get back to us.
Aug 2, 2024 at 10:55 AM
