on my mater cylinder, i have two lines that come out. Which line or both are for the front brakes? Thank you, very much!!! Kurt
Jul 27, 2010 at 9:23 AM
HMAC300
CERTIFIED EXPERT
if you have on side of the master that is larger than the other meaning bowl size then it's the line on that side. If they are both the same it should be the rear line (closest to firewall or booster).
