1983 Chevy Camaro idle to hi
1983 CHEVROLET CAMARO
44,000 MILES • V8 • 2WD • AUTOMATIC
PETESAIRE
i installed new procomp manifold with new adapter plate from 4 bbrl to 2 bbrl now it idles to hi cant seemed to idle it down
Feb 25, 2010 at 10:24 AM
MIKE H R
  • 3,094 POSTS
What it sounds like is that there is a air leak. Check the plate. There are sprays that detect leaks you spray around the intake. If there is a leak the engine will change rpm. First check the idle screw and linkage. The throttle could be sticking. If that is the case then you might have to put a heaver return spring on.
Feb 25, 2010 at 10:38 AM
PETESAIRE
should i spray gas on intake
Feb 25, 2010 at 11:23 AM
MIKE H R
  • 3,094 POSTS
use the spray on the intake where you put the adapter plate and around the area. Check any vacuum lines making sure they are good.
Feb 25, 2010 at 11:59 AM
