Electrical problem
1981 Chevy Camaro V8 Two Wheel Drive Manual
when i push the brake pedal, all the dash lights and the front parking lamps come on also. i have checked all the bulbs, all are the proper dual filament bulbs that are not burnt out. the car has a new headlight switch and a new brake light switch. i noticed when installing the brake light switch that this happened even when only the power wire harness of the switch was plugged in. so best i can figure, the switch is pushing the power back up through the taillight line when the brakes are pushed. i've checked all the fuses and am out of ideas. everything i can find online says to check the bulbs, but all is well with them, like i said.
Jul 1, 2010 at 11:20 AM
