Engine Cooling problem
1979 Chevy Camaro V8 Two Wheel Drive Automatic
What tools do I need for Water Pump removal on a 1979 Camero. I noticed when you get to the step of loosening the power steering pump, the bottom bracket nut has an different shape to it...seemingly a shape that would require a crecsent wrench. However the area is very tight fitting and does not appear to leave any room for any good torque in order to loosen it. Would I need a special wrench for this process?
Thanks.
Thanks.
Feb 5, 2009 at 11:22 AM
