1979 Chevy Camaro no electrical at all
1979 CHEVROLET CAMARO
100,000 MILES • V8 • 2WD • AUTOMATIC
DCS1242
hello i have a 1979 Z28 camaro 350 engine, i have this electrical problem i guess. well when i turn my ignition switch i get no power no voltage, nothing at all lights dont turn on i mean nothing at all, and the engine does not turn over or crank. so i took the starter and battery off and took it to be check, turned out to be that the starter was good but the battery was not so i got a new battery.so i replaced the old battery for a new one and put the startwe back on and tried to start the car again and the same thing happened. the engine would not turn over or crank, i have no power or voltage. so what do think is the problem if you can give as much as possible information to get my car working
May 15, 2010 at 12:08 AM
Check and test all the fusible links at the starter if okay test the ignition switch
May 15, 2010 at 6:07 AM
