1979 Chevy Camaro battery drain
1979 CHEVROLET CAMARO
150,000 MILES • V8 • 2WD • AUTOMATIC
JIMPOWELL
i have a slow battery drain test light half lit key off ive pulled the fuses,dont help. maybe alternator or ignition?
Dec 21, 2007 at 2:27 PM
MERLIN2021
  • 17,250 POSTS
Get an analog voltmeter remove the negative battery cable, attach the red lead to the battery post, black lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were!
Dec 21, 2007 at 3:55 PM
