i replaced my rear wheel brake cylinder and i have bled out all the air out ! i just happened to noticed that my master cylinder was leaking so i bought a new master cylinder ! i bled the brakes again to make that the brakes has no air ! then i found out the rear brakes wasnt expanding out to stop the rear tires from spinning ! while someone the brake padel pressed down all the way i can still rotate the rear tires by hand ! so im getting no pressure to the back brakes ! what causing this problem ? portportioning valve ?
Mar 17, 2010 at 7:31 PM
