Drive Train Axles Bearings problem
1972 Chevy Camaro V8 Two Wheel Drive Manual
I have a 1953 Chevy truck with a 383 that I recently (several hundred miles ago)changed over from a Turbo 350 automatic to a Tremec TKO-500 5 speed with a hydraulic clutch. The rear end is out of a 1972 camaro. If I am cruising down the road at a constant speed and step on the gas to accelerate, the back end moves to the right (sort of fish tails) and front then steers to the opposite side. Likewise if I am cruising in less than 5th gear and suddely take my foot off of the gas, the same thing happens in the opposite direction as I decelerate. The problem was very slight at first, but seems to be getting worse. I'm thinking it is a problem with the rear end unequalliy transfering power to the wheels, but don't know. Any suggestions on what the cause may be or how to determine what the cause is?
Aug 25, 2009 at 10:42 PM
