I have a th350 transmission and this pan has always given me trouble. I cannot stop it from leaking. After having the car sitting in storage for over a decade i changed the fluid in the tranny along with the fiiler, gasket and the gear selector seal as I 'm getting ready to place the car back on the road. After tightening up the gasket lightly at first and more as I added the fluid since some weren't tight enough and sprang leaks I still cannot get the front rim of the pan to seal properly. I've already checked the front seal and it is dry as can be and can clearly see the fluid coming from the pan gasket and no where else. Is it possible that the pan flange or rim is slighlty warped from previously being over tightened? What can I can to remedy this situation shy of replacing the pan or is that my only alternative. Thank you so much for your help since it keeps me up a night only to run to the garage in the morning to see if it has stopped.
Aug 15, 2008 at 8:53 AM
