vacuum accumulator??
CHEVROLET BLAZER
65CHEVYTRUCK
I have a '97 Chevy Blazer, 167k miles, auto trans, 4.3L engine, 4wd. Just changed the alternator, now no air blows out of the vents, seems to be stuck in defrost/floor mode. Last time this happened, it was the vacuum accumulator. Chiltons doesn't show how to check if that's the problem. Any advice?
Aug 28, 2007 at 12:48 PM
CLY
  • 308 POSTS
There is vacumm line that runs right behind the alternator. Follow that line to see if it came off. I think that the vacumm canister is probably disconnected. If you dont see that line then look for a vacumm ine coming from the firewall on the passanger side and follow it to see where it goes...
Cly
Aug 28, 2007 at 4:36 PM
