transmission problem
CHEVROLET BLAZER
PRETTYGIRL
2001 chevy blazer 140,000 miles 4.3 v6 4x4 its the transmission it will not take drive i mean when you put it into drive it does not go forward.all the other gears are fine p,r,1,2.what is going on.
Feb 26, 2007 at 4:57 PM
CHEVY22
  • 1,375 POSTS
has there been a check engine light on ???
the info given of the cable adjustment is wrong and probably will not help , if you really want to check the cable place the transmission in park and set the parking brake , pul cable from the shift lever on the transmission and see if the shift lever will move forward at all if so adjust the cable accordingly , but if your guages rare reading properly i would suspect another problem let me know
jim
Mar 2, 2007 at 10:15 PM
