I have a 1998 blazer 2wd 4.3L V6. After removing the heads and replacing a blown head gasket, I can't get the rocker arm nuts to stay tight. I replaced all of the nuts (12) with new ones. I took out the lash and turned each nut 3/4 of a turn as the book stated. Do you adjust it while running?
The Haynes repair book gave two adjusting points, on TDC for #1 and TDC for #4. I followed instructions but some nuts are still coming loose.
Thanks
Thanks
Jun 22, 2007 at 7:11 AM
