No power to USB Port!
CHEVROLET BLAZER
CANDYXTREMEBLAZE
I have a 2001 Chevrolet Xtreme Blazer with 138000 miles 4.3L Vortec! I have no power to the USB Port. I have checked all fuses there is no power running through the wires either. Could you tell me if there is anything else I could check in order to get power back to the port??
Thank You,
Ami
Jul 21, 2007 at 9:41 AM
CHEVY22
  • 1,375 POSTS
DO YOU MEAN THE POWER PORT ??
JIM
Jul 22, 2007 at 8:16 AM
CANDYXTREMEBLAZE
Yes I ment power port! LOL
Jul 22, 2007 at 6:11 PM
CHEVY22
  • 1,375 POSTS
IF YOUR SURE YOU HAVE CHECKED ALL OF THE FUSES CHECK YOUR CORD TO SEE IF IT HAS A FUSE IN IT , SHOULD TELL YOU IN TH QWNERS MANUAL
Jul 22, 2007 at 8:50 PM
CANDYXTREMEBLAZE
Ok I will check the owners manual out. The pollution control pipe that comes out of the manifold had busted and melted my wiring harness, but the power port had not been working before this happened. Now the trans will change into 1st and 2nd and when it gets to 3rd it's like putting the engine in netural and reving the engine up, so thats why I am trying to get the power port to work, so that when I hook it up to a computer I can pin point the problem. Thank You for your advise!!!!
Jul 22, 2007 at 9:29 PM
CHEVY22
  • 1,375 POSTS
ALSO CHECK THE CIG FUSE THAT WILL DO IT TOO
Jul 22, 2007 at 10:05 PM
