leaking transmission fluid
CHEVROLET BLAZER
MAUIKIMCHEE
94 Blazer leaks trans fluid when in gear from housing by torch converter.Changed the rear seal and now it seams to be worse.Any idea's what it could be and the best scenario for the problem?
Thanks,
Mauikimchee
Apr 26, 2007 at 4:09 AM
JUNEDOG
hello a common problem with the 4L60e transmission leaking fluid from the bell housing is the pump bushing located behind the front seal spins in the housing and gets pushed up against the seal.it lets fluid run out of seal.
Jun 2, 2007 at 9:08 AM
