'87 K5 blazer 321 000km thud noise when turning corners
1987 CHEVROLET BLAZER
TREES
  • 14 POSTS
Around 200 000 miles
My truck makes rapid 'thud' noises when I corner on dry pavement, the problem persists on snow but isn't as bad. Power steering does not go hard, No leaking fluids of any sort, Transmission replaced 5 years ago. Do I have a U-joint problem or something else?
Nov 16, 2006 at 10:34 PM
BADSTANG79
  • 11 POSTS
hey, my friend has a bronco that did the same thing. it ended up being the bushings on his sway bar i believe. or the stabilizer. anyway have somebody turn the wheels for you while your under the truck, and just look and listen for binding problems.
Nov 18, 2006 at 1:51 AM
TREES
  • 14 POSTS
I only hear the sound when i am moving which would suggest U-Joints.
Nov 18, 2006 at 12:29 PM
BADSTANG79
  • 11 POSTS
ya, i dont know what to tell you. his truck made the noise all the time. it was the end links on the sway bar. sorry i wasnt much help.
Nov 20, 2006 at 12:25 AM
