HI! I like your initiative!
Wheel bearings do not need to be replaced in pairs. However, it's not bad idea to check the second side since you already have to tools out.
When looking at parts online, you will generally find them cheaper online than at your local parts store because they don't have to pay for as many buildings or employees. Generally, you will have to wait longer for your parts to arrive and they will be more difficult to warranty them out or exchange them if the wrong part arrives. So, you need to balance the pros and cons.
I am also including the remove and replace procedures. If you don't have a torque wrench maybe borrow your son's for the reassembly. The right torque is important. Good luck! Let us know how it turns out!
This is the install:
Installation Procedure
1. Install the wheel hub and bearing seal to the wheel hub and bearing assembly.
2. Install the splash shield to the steering knuckle. Align the shield to the steering knuckle.
3. Install the wheel hub and bearing assembly to the steering knuckle. Align the threaded holes.
4. Install the wheel hub and bearing assembly to the steering knuckle mounting bolts.
^ Tighten the wheel hub and bearing assembly to the steering knuckle mounting bolts to 105 Nm (77 ft. lbs.).
5. Install the wheel speed sensor to the wheel hub and bearing assembly.
6. Install the wheel speed sensor to the wheel hub and bearing assembly mounting bolt.
^ Tighten the wheel speed sensor to the wheel hub and bearing assembly mounting bolt to 18 Nm (13 ft. lbs.).
7. Install the rotor. Refer to Brake Rotor Replacement - Front in Brakes and Traction Control.
8. Apply the brake pedal.
9. Install the drive axle washer.
10. Install the drive axle nut.
^ Tighten the drive axle nut to 140 Nm (103 ft. lbs.).
11. Install the tire and the wheel. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
12. Load the torsion bar. Refer to Torsion Bar and Support Assembly Replacement
13. Lower the vehicle.
Here is a video that can help
https://youtu.be/_FzmmBoa4Tg
May 14, 2021 at 12:12 PM
(Merged)
