new vehicle to me. I put new cat @ muffler, plugs-wires-cap @ roter, fuel filter, cleaned throttle body, and I was told it had a new fuel pump, it looks fairly new, the filter was really pluged, and vehicle performed the same. Fuel pressure on rail is 52 psi with eng running-55psi with vac applied by hitting throttle, I put gague on filter with eng off, cycled key and rt was 58psi at best. Is fuel pressure ok ? I got 3 02 codes-po131-po137-po151-the 02's look like the switching is good until you hard acell, then all 3 02's go to real low readings and stay there, fuel pump ? I do not know what it should be. HELP. Thank's.
Aug 1, 2010 at 7:14 PM
