2001 Chevy Blazer water in oil
2001 CHEVROLET BLAZER
128,500 MILES • 6 CYL • 4WD • AUTOMATIC
WUDBRDGGAL
oil is an opaque light brown color, what would cause this and what repair is required?
Aug 21, 2008 at 10:57 PM
JETSA
  • 117 POSTS
Oil is discolored due to water or antifreeze mixed in with the oil. Intake manifold gasket leaking is the most common cause. Obscure causes are internal engine failures or if the radiator has an oil cooler, the oil cooler inside of the radiator leaking internally mixing oil with the antifreeze.
Aug 22, 2008 at 9:08 PM
