I need the radio wiring diagram?
2001 CHEVROLET BLAZER
112,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRETTBRAN
I need the radio wiring diagram for a 2001 Chevy Blazer to an aftermarket radio (eonon 821) thats made in china.
Thanks[img:b039bd4af0]http://www.2carpros.com/forum/automotive_pictures/349617_Eonon_821_wiring_1.jpg[/img:b039bd4af0]
Thanks for getting back to me. I have the harness's for both. No one (Audio Installers) has them configured to match, that's why I posted the wiring diagram from Eonon unit. My question is. What do the GM wires hook up to on the Eonon wiring diagram provided.
Please Match this up to Eonon wiring diagram. At this point what I'm requesting should be obvious. Again thanks, I hope this will be answered.
Brett
For Blazers and S-10s (including Bravada, Sonoma, Jimmy, Full-Size) the actual stereo wiring is as follows
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Jun 16, 2010 at 4:32 AM
RACEFAN966
  • 5,029 POSTS
You go to you local stereo shop or Amazon and get a wiring harness adapter kit. This you wire to the stereo and then it simply plugs in. Here are both wiring diagrams for amp and no amp models.
Jun 16, 2010 at 10:38 AM
RACEFAN966
  • 5,029 POSTS
A harness adapter to you do not have to cut any of the cars wiring harness as this will cause problems and be a real mess. The harness adapter should also tell you what wire does what connect them in that manner and then simply plug it into the car. If need be go to Crutchfield on the internet. Here is a pic.
https://www.2carpros.com/forum/automotive_pictures/249564_h120701858fp_2.jpg
Jun 18, 2010 at 9:10 AM
CHEVYGUY7
Electrical problem
Hi i need to know what colors go with the wiring system for the stereo on a 2001 Chevy Blazer, I'm trying to hook up an amp and sub woofer and need to know the color to cut and add into a high low converter, the color i need is the rear speakers on the back of the stereo.
Thanks CJ
Oct 23, 2019 at 2:01 PM (Merged)
I have found both amp and non amp wiring diagrams for you so you can get the tunes going :) (below) Please let us know if you need anything else to get the problem fixed. (CLICK TO ENLARGE)
CHEVYGUY7
Thanks you guys I love this site!
TROYIUTZI
front door speakers
CJ MEDEVAC
  • 11,004 POSTS
ok---my 1st diagram is "with amplifier"
the 2nd is without
let me know if you cannot read these---i don't know how they will look on 2car till i submit them....i can help you get them without blurting out your personal info on open forum THE MEDIC
TROYIUTZI
Thanks!
TROYIUTZI
I was replacing the door speakers and needed to confirm + wire - wire for the speakers.
CJ MEDEVAC
  • 11,004 POSTS
welcome!---my eyes were once like yours. in the download i could see no problem. once posted it was a different story
the medic
KUZOMOTO
i had got my blazer back and i was checking if the main harness was there but it was cut off and connected to a radio and i wanted the harness there so when i buy another harness to clip to the main harness i wont have to worry much of wiring connections
I'm not sure what you are asking, but it is common for people to cut the OEM harness when using an aftermarket radio. Here is the stock radio wiring diagrams. Check out the images (Below). Please let us know how it goes
FIXITMR
  • 9,990 POSTS
you could try to locate a used harness that matched your original and wire it in? or maybe they actually make aftermarket harness replacements?
