2001 Chevy Blazer noise
2001 CHEVROLET BLAZER
134,357 MILES • 6 CYL • 2WD • AUTOMATIC
JESSE480
my car make this nosie in the front left tire but i dont know if its the tire. when i drive and it hits 30 it starts making this noise like a little motor gettin louder as i go faster its not the motor thats one thing i kno so can you help me out pleas
Jul 18, 2010 at 11:32 AM
EDWARD.S
  • 166 POSTS
Hi, Sounds Like You Have A Bad Front Hub Bearing, Check For Play In Front Wheels ,By Putting A Floor Jack Under Lower Control Arm , Lift One Side At A time .Make Sure Wheel Is Off Ground A Couple Inches ,Take One Hand At 12:00 Position And One At 6:00 Position ,Move Wheel Feel For Play , If no play, Spin Each Wheel By hand Fairly Fast ,Listen Closely To Both Sides , If One Side Is Much louder Than Other Side, I Would Replace That Side Hub Bearing.Do Not Start Car While Checking This.
Hope This Helps You,
Good Luck.
Edward S.
Jul 18, 2010 at 11:58 AM
