Do you have a scan tool that reads sensor data? If yes, start the truck, attache scanner, tap on head near the knock sensor, look for change in the way the graph or line representing the sensor looks, also check for timing to retard a bit when you tap, if these happen, the sensor is OK! As far as location I only posted what I found, havent replaced too many of them!
Jan 29, 2021 at 10:32 AM
(Merged)
