My front drivers side cv joint went bad. I have the vehicle tore down right now. I've already removed the hub assembly and everything else on the control arm to remove the drive axle. I can not get the inside of the axle loose. Is there anything besides using a prybar and hammer that is needed to remove this?
Thank you in advance
Matt
Matt
Mar 21, 2008 at 3:41 PM
