2001 Chevy Blazer Driver side door
2001 CHEVROLET BLAZER
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
JPHAINS
  • 5 POSTS
Driver door on 2001 Blazer 4dr will not close. Door also seems to be off, not hanging properly. When the door does shut, you have to lift up on the door a bit to get it to align with the latch. Any way to fix this, tighten up the hinges or something?
Thank You
Nov 30, 2008 at 5:15 PM
Hi:
The actual hing is welded on. However the pins are replaceable. The new ones will come with new brass bushings. That should take care of the problem and they are inexpensive.
Dec 1, 2008 at 9:12 PM
