my wifes blazer has no acceleratio at all. i mean with the pedal to the floor it acts like it is towing a semi truck. any suggestions ?
Jun 14, 2009 at 6:23 AM
2CARPRO JACK
CERTIFIED EXPERT
Loosen the exhaust before the cat converter to see if you have restrictive exhaust.It will be loud, but it will run ok if the cats are the problem
Jun 14, 2009 at 8:49 AM
LINKONCOLT
MEMBER
are you saying that a restricted cat could be the problem ?? unhooking it is the only way to determine if it is a restricted cat ?
Jun 15, 2009 at 6:17 AM
2CARPRO JACK
CERTIFIED EXPERT
It isn the only way, a backpressure gauge can be installed to see if it has too much, loosening the pipes is a quick way of seeing if it is the problem, and it is something you can do yourself
