2001 Chevy Blazer ABS
2001 CHEVROLET BLAZER
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
PDPARTIST
I started the car, got an ABS warning light. There is a pump under the hood that is running continuously, even when I turn off the car. Brake fluid resevoir is full. I pulled the ABS fuse (60 amp) to get the pump to stop running. Now I am lost. What could be the problem ?
Jan 12, 2008 at 5:21 PM
PETEBROWN
  • 0 POST
[quote:67223e8e93="pdpartist"]Brakes problem
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic 75000 miles
I started the car, got an ABS warning light. There is a pump under the hood that is running continuously, even when I turn off the car. Brake fluid resevoir is full. I pulled the ABS fuse (60 amp) to get the pump to stop running. Now I am lost. What could be the problem ?[/quote:67223e8e93]
Jan 16, 2008 at 1:27 PM
