2000 Chevy Blazer trying to install new transfer case actua
2000 CHEVROLET BLAZER
WILLIAM CHOQUETTE
Drive Train Axles Bearings problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic
need to know how to remove front drive shaft from t-case? Ihave already disconnected at u-joint, but the end that is attached to t-case seems to be stuck.
Nov 17, 2009 at 7:25 PM
DOODYDP
  • 4 POSTS
IT may be stuck. According to the Haynes manual all you should need to do is pull the strap bolts from the front of the drive shaft and then drop the front of it and the rear should slide out of the transfer case. It is just a CV joint splined to the transfer case.
Is it still on the vehicle or did you drop the transfer case already?
Dec 21, 2009 at 11:57 PM
