the electronic shift button works on all 2h.4h.auto, 4lo. when i put it in 4 hi it works,when i put it in 2 hi it works. if i had it in 4 hi on hard surface would the tires roar?is that normal? the truck roars in all settings,auto,2 hi,4hi .so what you are telling me that the only thing that causes tire roar is a bad wheel bearing,tires are bad,or 4 wheel drive not fully disengage. so tire rods,idler arm,pitman arm,and ball joints will not cause roaring right or wrong ?what is the best way to check 4 wheel not disengageing,and how can i be sure it is a wheel bearing ?i want to find out were to begin ? thanks
Jan 28, 2010 at 7:29 AM
