I have the common EVAP code P0452 fuel pump had been replaced. I had a leak and fixed, replaced vacuume lines, Replaced purge valve, checked valve in the back under the spare tire and tested good, checked charcoal canister not plugged, replaced pressure sensor, replaced gas cap,
pulled out fuel pump and made shure the rubber gasket was sealing. I went through all of my fuses and relays and cleaned terminals. When I clear the code i can drive it without comming on untill i shut the vehice off and start it back up again.
Any Suggestions?
Any Suggestions?
Jun 19, 2008 at 1:41 AM
