2000 Chevy Blazer brakes and abs
2000 CHEVROLET BLAZER
CURTISB2002
Brakes problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic
changed out the hub kit on passenger side of blazer. the hub and bearing were all one piece. changed ball joints on both sides also. Now when i come to stops signs and lights i slow down about 20 foot before and right when i almost get completely stopped the brake gets hard and kinda bounces till i stop then when it gets completely stopped it goes in as normal. i change the abs sensor once now and it still does it unless the abs light on dash comes on and brake system works fine untill abs light goes off then it goes back to being hard when i get almost stopped.
you can also here the winding noise when the brake isn't wanting to go down>
thank you
Jan 27, 2010 at 2:09 PM
SCOTTY DEE
  • 592 POSTS
I assume you've checked the caliper brackets for tightness?
Jan 28, 2010 at 8:19 PM
SCOTTY DEE
  • 592 POSTS
There could be an ABS hydraulic control unit problem.. Have you scanned the ABS module for codes?
Jan 28, 2010 at 8:21 PM
