2000 Chevy Blazer 2000 Chevy Blazer problems
2000 CHEVROLET BLAZER
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
LABGUY3636
Hey guys,
Driving down the road yesterday and noticed the dashboard warning lights flickered on and off for a second as I was driving and the car just died. I put it in neutral to coast and tried to re-start and there was no power whatsoever. When I turned the ignition switch it was as if there was no battery connected. Initially, thought it was the alternator. Got it home and put a voltmeter on the battery and showed good voltage (12.95). Checked the battery cables and no corrosion and connections were good. What should I check next now?
Jun 27, 2010 at 7:41 AM
HMAC300
  • 48,601 POSTS
check your underhood electrical center an dsee if one of the larger fuses have blown out. they are 40 amp to 60 or ven 125 amp. if those are all good, then check by the starter for a burnt fusible link, they are smaller wires going to larger wires.
Jun 28, 2010 at 5:56 PM
