My 1999 s-10 blazers turn signals just all of a sudden stopped working , there is nothing when you raise the lever up or down to signal , fuse is good and has current when switched on , i was told to check the turn signal flasher i can only find one flasher that is behind the glove box that reads combination flasher it has four prongs could this be my problem ? the multipupose switch on the steering wheel all other functions work fine
Jan 25, 2010 at 5:57 PM
