1999 Chevy Blazer Odometer display
1999 CHEVROLET BLAZER
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
PALUTZ
The odometer works but only iluminates when the weather (and car interior) is cold. After the car interior warms up, the display turns off. Could this be as simple as a loose connection inside the dashboard?
Jan 10, 2008 at 3:59 PM
PEAR69
  • 1,482 POSTS
No, these dispalys are famous for this problem. There is a diode on the circuit board that has gone bad. When it's cold the diode makes a connection; then, when it warms up the connection opens.
There is no way to fix this problem other than replacing the entire display. You can find good deals for these displays on ebay.. Good luck
Jan 10, 2008 at 8:39 PM
