1999 Chevy Blazer Front End Making Noise and Pittman Arm
1999 CHEVROLET BLAZER
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
DALLAS09D
I just had the upper cotrol arm fixed on my 1999 Chevy Blazer on the driver side. I just had it replaced and now when I put it in reverse it is making a popping noise but its coming from the passenger side what could that be? My alignment is out pretty bad pulling right and I have drive this thing tomorrow 4 hours going 75 you think that will be ok?
Jan 26, 2010 at 3:19 PM
SCOTTY DEE
  • 592 POSTS
Sounds as if the lower ball joint on the passenger side may be worn out. Raise the suspension by placing the jack under the lower control arm and raise the vehicle. Use a long prybar underbeath the tire and pull up on the prybar while watching for any movement in the ball joint.
Jan 27, 2010 at 7:37 AM
