1999 Chevy Blazer change in temp out side affecting proform
1999 CHEVROLET BLAZER
175,000 MILES • 6 CYL • 4WD • AUTOMATIC
ARGON
when the temp outside goes up the car runs better, when it is cold it will backfire, no codes. this all started after the engine was replaced, also the milage went down to 10 miles per gallon, till it warms up out side, it went back up for a short time when i had the front and rear punkins rebuilt. reviewed all connections for the past year and replaced numerus parts < mass air flow, temp censor , tune up , etc.
Apr 25, 2008 at 8:23 AM
RHALL77
  • 3,361 POSTS
sounds like a temp sensor or something else wasnt plugged in when they did the engine. i would look and see if anything is disconnected under the hood.
Apr 25, 2008 at 8:43 AM
ARGON
checked all connections over and over, what in this auto would let outside temp effect the engine so dramaicly ?
Apr 25, 2008 at 8:56 AM
RHALL77
  • 3,361 POSTS
(MAT) manifold air temp sensor, coolant temp sensor, O2 sensor if it is reading lean
Apr 25, 2008 at 9:49 AM
