1998 Chevy Blazer play in steering wheel
1998 CHEVROLET BLAZER
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHIEFCATCHEMALL
  • 17 POSTS
I have probable 2 inches of play in my steering wheel. from what i understand its a common problem with the blazers. wheres a good place to start guys?
Jul 17, 2010 at 1:19 AM
EDWARD.S
  • 166 POSTS
The First Thing I'd Check Is The Sterring Shaft,Going Down To The Sterring Box Look Clostly At The U Joint On That Shaft. for Looseness, And Rust At Caps . Also Check the Idler Arm And Pitman Arm ,A High Failure Rate On These Trucks ,
Good Luck ,
Edward S.
Jul 17, 2010 at 6:58 PM
CHIEFCATCHEMALL
  • 17 POSTS
Its been like this for a few years. Doesnt seem to be getting any worse. Is it safe to drive until I get the money together to fix it?
Jul 17, 2010 at 8:47 PM
EDWARD.S
  • 166 POSTS
Hi, What I Would Do Is Have The Whole Front End Checked Out By Your Mechanic .Then You Will Get A Better Idea.If It's Safe Or Not,Too Drive.
Good Luck,
EDward S.
Jul 18, 2010 at 5:39 AM
CHIEFCATCHEMALL
  • 17 POSTS
Got a camping trip up north about 2 hours away coming up in a week. Tight on money. Its gunna have to wait a couple weeks unfortunately...
Jul 18, 2010 at 7:31 PM
